I'm having trouble getting my Super Deluxe to a balanced point that suits the riding I do on my Voima (190mm). It's a RS-SDLX-ULT-B2, so it's only got LSC and Rebound adjustments.
Thoughts? What else can I try here? I feel like I need more LSC and LSR without increasing the HSC or HSR, but not sure about increasing the mid support? Regardless, I have no high-speed knobs to adjust!
- @30% sag, impacts feel quite harsh despite not using all travel. Seems like its blowing through mid stroke and coming to a harder stop towards the top end of the spring curve
- Small drops easily use all travel. Never a harsh bottom out at all, but I can get the red travel band off the end of the shaft
- Less sag loses the small bump sensitivity, causing the rear ends up skipping over the smaller impacts
- Adding LSC seems to help with the mid stroke support, but again at the expense of sensitivity
- Faster rebound improves compliance and helps down serious rock gardens, but bucks me forward on any small jump/drop, also bounces me around when climbing up tech
- Slowing rebound to prevent the bucking/bouncing leads to rougher ride overall, presumably where the shock is packing down between impacts
