Stereo 140 2021 front sag?
AF1
89
62
Hi, I'm trying to set the front sag but there are no markings or orange band on my forks - FS-35S-TK-A1.
Does anyone know how to do it please?
Northerncube
10
Hi, usually the manufacturer of the fork will go you an air pressure for your weight as rough guide.
You can loosely wrap a cable tie around the fork where the band would be and use this to get the sag then just cut it off after.
hope that helps. ??
AF1
89
62
Hi Northerncube, I have used the Zip tie method on other bikes where they give you measurements to work to, but I don't know where 20% or 30% is on my forks! The RockShox video says "if you don't have markings, go to 'Service'" but in fact there's nothing there to assist.
Northerncube
10
The only other way I could think is measuring the fork travel with a tape measure.
I think I’m right in saying if you have 120mm of actual fork travel 20% would be 24mm
You could then put the cable tie on until you get it to this distance from the fork crown.
MrPeaski
260
210
South Wales
For a 140mm fork, 20% of travel will be 28mm, for 30% it will be 42mm.
If the fork is 150mm 20% will be 30mm, for 30% it will be 45mm
This is measured from the top of the fork seal to the underside of the zip tie
Start with these and see how it feels
Northerncube
10
Sorry if I’m asking you a stupid question but the recommended pressure table isn’t on the back of one of the fork legs is it.
mic seen that on some rock shox before.
AF1
89
62
Great idea guys, its Stereo 2021 with 140 forks so 20% of travel will be 28mm, for 30% it will be 42mm. I'll see if the rough air pressure setting is correct now. Many thanks both.
AF1
89
62
I had found and used the table on the back of the forks, just wanted to do it properly.
MrPeaski
260
210
South Wales
You should also set the suspension up in your riding gear. i.e with back pack water bottle etc or anything you carry on yourself and bike on a normal ride.
If you set it up without, there's a chance that 'fully laiden' it'll be a bit too soft.
The best thing is to use the numbers as a starting point and tune to suit how you ride
AF1
89
62
Thanks Peaski, I have now read the article so should be sorted. Why RockShox put graduations on the Rear Shock but not on the front is anybodies guess, must have saved a penny :)
Northerncube
10
I agree, the fox forks on mine have the band but no marks on the forks so it’s not as easy to work out, would be nice to have just an easy visual reference
makes things a lot easier when they do.??
MrPeaski
260
210
South Wales
Must admit, when setting up my current bike (2020 Stereo 160) I didn't measure it. I just set it by eye and rode it.
Front ended up spot on, but needed a bit of air in the rear shock
Both are set to around 30%
  • Like
Reactions: AF1
AF1
89
62
Still on shock setup, I have noticed my compression adjuster only moves 90deg and does not click at all. The Rebound is very stiff, also turns 90deg and clicks 4 times - if I push it in it turns without clicking. Is all this normal please?
553K
