Levo Gen 2 SPECIALIZED TURBO LEVO-CHANGING GEAR CABLES
Kath Harpley
Whitby
Hi guys. Help please. I want to change the inner and outer gear cable on my Levo Turbo. I have done this before on my Scott which was externally routed. Never done an internal routing before. Can anyone point me in the direction of a step by step guide to do this, on this particular e-bike. I have checked out You Tube videos so have the basic idea but need to know how to release cables etc. Any help appreciated.
James_C
530
269
Kent, UK
I've been through a few inners but left the outer in place so far. This is relatively easy, assuming you don't make the mistake of dismantling the shifter completely which explodes into 20 pieces.
you might want to try the inner only first depending on what your issue is with the cable.
KennyB
824
564
Taunton
haven't seen that, what was the thinking behind it? presumably that bit wears out quicker?
Pretty much. Moisture and fine dirt can get in, also I find that the derailleur end is easy to get kinked as it can be exposed.
552K
