Specialized release 2019 29" Levo Hard Tail - £2249
Rob Rides EMTB
Administrator
Staff member
6,260
13,699
Surrey, UK
Specialized have just released the 2019 Levo HT. Quite a big diffreence between this one and the resular FS Levo. It is a budget friendly bike, and the components reflect the £2249 price tag.
The same 1.2E motor as the 2019 Kenevo (I am waiting for confirmation from Specialized if its any different to the 2017 motor).
Key Specifications
  • Frame - M5 Aluminium
  • Fork - SR Suntour XCM32 100mm
  • Drivetrain - Shimano Acera 8 Speed
  • Brakes - Shimano MT200 Hydraulic Disc
  • Motor - Specialized 1.2E Custom 250W
  • Battery - Specialized 400Wh
Full Specification
  • Frame - Specialized M5 Aluminum, 29 Trail HT Geometry, integrated down tube battery, enclosed internal cable, Command Post routing, 148mm spacing
  • Fork - SR Suntour XCM32, 47mm offset, 15x110mm thru-axle. (S: 100mm travel, M/L/XL: 120mm travel)
  • Shock - n/a
  • Number of Gears - 8
  • Shifters - Shimano Acera, 8-speed
  • Chainset - 2D cold-forged alloy, custom offset, 165mm
  • Chainrings - 32
  • Cassette - Shimano HG41, 8-speed, 11-34
  • Chain - KMC X8 w/ Missing Link™, 8-speed
  • Front Derailleur - n/a
  • Rear Derailleur - Shimano Acera, SGS cage, 8-speed
  • Bottom Bracket - Integrated
  • Pedals - Not Available
  • Rims - Specialized Alloy 29", 18.3mm depth, 25mm internal width, disc-specific
  • Front Hub - Specialized, sealed cartridge bearings, 15x110mm thru-axle, 28h
  • Rear Hub - Stout Pro, sealed cartridge bearings, 12x148mm thru-axle, 28h
  • Front Tyre - Ground Control, GRID casing, GRIPTON® compound, 2Bliss Ready, 29x2.3"
  • Rear Tyre - Ground Control, GRID casing, GRIPTON® compound, 2Bliss Ready, 29x2.3"
  • Front Brake - Shimano BR-MT200, hydraulic disc, 180mm
  • Rear Brake - Shimano BR-MT200, hydraulic disc, 160mm
  • Brake Levers - Shimano MT200 Hydraulic Disc
  • Handlebars - Specialized Trail, 6061 alloy, 8-degree backsweep, 6-degree upsweep, 27mm rise, 780mm, 31.8mm clamp
  • Grips - Specialized Body Geometry XC, clamp-on
  • Headset - Included
  • Stem - Specialized, 3D-forged alloy, 4-bolt, 6-degree rise, 31.8mm clamp
  • Saddle - Henge Sport, steel rails, 143mm
  • Seatpost - Specialized 2-bolt head, forged alloy, 8mm offset, micro-adjust, 30.9mm
  • Post Clamp - Included
  • Weight - Not Available
Kernow
1,436
1,149
Cornwall uk
Nice looking bike as spesh usually are , but how they can call that spec / price combination budget friendly beats me , they must be relying on potential customers being unable to compare or understand specs of components for that to sell at that price against the competition .
Al Boneta
Dark Rider
1,351
2,602
California
Yeah, I don’t see the logic behind this either. I doubt I’ll stock these in my shop. It needs to be closer to the price of the Turno Como 3.0 to be competitive
554K
