Rich-EMTB-UK
Hi,
Just changed the stem on my bike from 50mm/35mm to 35/35mm. New stem is not a high as previous stem and is carbon. I have added an additional 5mm spacer under the stem and an additional 5mm above the stem so that the top cap fits correctly and there is no play in the steer.
Would you have done it that way or just added 10mm under the stem, without the 5mm top spacer the steer was only about 2mm lower than the stem. Instructions for the Stem seem to recommend a spacer on top as well.
