Telemarker
Noticed clonking noise on my Sam2 yesterday coming from shock area.
I happened to be 1km from shop where I bought it.
Took it to shop and mechanic reckoned lower shock bushings worn out and to call another colleague on Monday to sort replacement bushing.
When I got home, i decided to take the shock off, and found lower bolt was spinning, but threaded end wasn’t turning on non-drivenside.
Got bolt out and it’s snapped at start of threads, couldn’t pull shock of as part of snapped bolt was still inside shock bushing.
Got the broken stub out carefully andeasily with a drill and extractor.
Big problem is the bolt has a 0.5mm less diameter worn groove in it where it sat in frame on drive side I.e. the worn bit is 7.5mm diameter and undamged bolt 8mm
Worse news is frame mounting hole is also very slightly ovalised about 0.15mm in vertical plane...
So not sure a new bolt will fix this long term.
Emailed shop with photos, And description
Hope it is covered by warranty
Any other focus riders had an issue like This? Or warranty jobs
Bike is 3months old and done 1000km
No ebike for time being either
