Levo Gen 2 Shock/Fork Tuning. Worth it?
KrisScott1990
77
43
Edinburgh
Ordered the X2 and Fox 38.
38s due tomorrow.
X2 due mid feb and will be tuned by J-Tech before dispatch.
Should i get the 38s Tuned too before fitting them?
Ive never had a fork or shock tuned so its a little new to me and unsure if its worth the cost?
Or should i just get both from factory without tuning?
9,281
Don't pay extra for it, it's easy enough. There is a thread on here that contains all you need to know.
Read the first post of the suspension set up sticky topic at the top of the general EMTB forum.
Gary
Old Tartan Bollocks
10,496
10,702
the internet
Depends what James (J-Tech) means by "tuned"
What @steve_sordy is talking about is set-up. not custom tuning.
Custom tuning is not "easy enough" and takes a suspension technician with a lot of knowledge to perform the relevant modifications to compression and rebound shim stacks, valving etc.
"tuning" can IME be a bit of a waste of time if the rider doesn't really know exactly what they want that tuning to achieve.
Gary
Old Tartan Bollocks
10,496
10,702
the internet
If you can be bothered to watch this (from about halfway through) you'll get an idea of the differences in various Fox dampers range of damping.
If the video just confuses you, simply watch it with the sound off and marvel at all the little internal parts Mr Sordy thinks are "easy enough" to tune ;)
:ROFLMAO:
KrisScott1990
77
43
Edinburgh
Tuned as in not setup but a custom tune.
I have opted for no tune, i dont want to send the 38s off when they arrive and wait extra for the X2. So going stock then when they need serviced i'll get them custom tuned too :)
Gary
Old Tartan Bollocks
10,496
10,702
the internet
It does make sense to have ridden the thing and found out what traits you do like and what you don't before having it custom tuned
KrisScott1990
77
43
Edinburgh
That was my thinking to. its going to be a totally differnt fork and the bike will handle different too. Want to understand it first before changing the characteristics of the fork :)
Konanige
422
336
Mendips
Yes custom tune is worth it, if your at the top of the weight range like i am you'll be right on the limits of the damping. I get mine done at the First service when I know how it rides.
KrisScott1990
77
43
Edinburgh
Yeah ill be at the top. im 95KG. Will likely get it done at first service then. Thanks for your help
552K
