• Warning!!
    UK Pedelec Law
    Worldwide Laws
Shimano EP6 / EP801 with PearTune or SpeedBox
aarfeldt
713
634
Denmark, Danstrup
Yes....LinkGlide 11 spd deraillure XT DI2 SHADOW PLUS RD-M8150-11, shifter SW-M8150-I and computer/display EN600.
The shifter is not absolutely needed, but I like to make manual shifts anyway.
aarfeldt
713
634
Denmark, Danstrup
The eMax software can (on EP801 motors):
- set speed limit to 50km/h (or is it 60 ?)
- set power to max 600w
- adjust wheel size if needed.
- some other stuff.
I set it to:
- speed limit 32km/h.
- power max 400w.
- enable electric shifting.
- rear sprocket max ring size: 50
Yesterday I went on a 32km ride, and it completed and at the end i had 32% battery left.
Bike: Orbea Rise M20 2023, upgraded fork, wheels, steeringbar, pedals, battery to large.
Mr-EPIC-3
188
124
USA, So Cal
- some other stuff.
I set it to:
- power max 400w.
So you are using the latest eMax mobile app?
What does a license cost?
aarfeldt
713
634
Denmark, Danstrup
No....using the Windows version is step 1.
License is 119 euro (100euro plus VAT)
This is currently not a DIY job.....maybe in a later version.
The german (very friendly and very helpfull) tech needs to be connected to your PC via AnyDesk (free and no installation needed) and do his magic.
It takes a couple of minutes, and he will communite on your pc in Notepad.
You can follow his steps.
When this is over, I'm using the mobile version in the trails (version 2.40 currently)
Mr-EPIC-3
188
124
USA, So Cal
OK, so I need to get a PCE1 or PCE02 Shimano connect device?
Mr-EPIC-3
188
124
USA, So Cal
Shimano warranty void if you derestrict.
Yes understood, any company that makes eMTB motor will void the warranty of their motor
If you de-restrict it. De-restricting to get another couple MPH/KPH shouldn't damage the motor, also Shimano specs the EP6/EP801 as a Class-3 (28Mph) motor in the USA.
Mr-EPIC-3
188
124
USA, So Cal
So with the exact same battery, software and motor here in Australia they are restricted to 25kmh, so in America 32kmh an hour is the speed limit so the Australian models could handle it easily at 32kmh without drama?
I am guessing, but I am sure that the EP801/EP6 motors are all spec and tested to handle 28Mph/45Kmh, speed limit is handle thru the software of the motor.
ggrin
51
20
Any pirate upgrades void the warranty. I got replacement EP8 motor for half price a year after end of warranty but I had to return first, so they could check it hadn't been hacked.
paske
47
33
Belgium
- some other stuff.
I set it to:
- power max 400w.
Wow, speed limit 32km/h, 32km ride and 32% left!!! Are you by chance 32 years old? :)
Mr-EPIC-3
188
124
USA, So Cal
Hi, does it work with Ep801?
I have been using the PearTune module on my EP6 motor for about 200 miles now with no error msgs, once I get to 500 miles I will say it's works. With that said the EP8/EP6 are the same motor/firmware tune from what I have read, just cover material is different. EP801 has different firmware tune, so not sure if it will pickup the PearTune module.
luna87824
436
1,169
Just South of The Grand Canyon
I have been using the PearTune module on my EP6 motor for about 200 miles now with no error msgs, once I get to 500 miles I will say it's works. With that said the EP8/EP6 are the same motor/firmware tune from what I have read, just cover material is different. EP801 has different firmware tune, so not sure if it will pickup the PearTune mod ule.
What's the part number of the Pear Tune module you are using?
554K
