Shimano E8000 power on issue?
Paddy
Chester
Hi I hope someone can help as i'm new to this Electric Mountain Biking.
Ive recently bought a Canyon Spectral:ON CF 7.0. it operates the Shimano E8000 motor with the battery housed in the frame. i got the bike shipped to me so put it together and had a quick go before putting the bike on charge (everything was working at this point!) by a quick go i was on the bike for 1 minute just up and down the road to ensure everything was tight i.e. brakes and gearing. i charged the bike for roughly 6 hours then went to go for a ride on it and the bike wouldn't power up. when i pressed the power button it illuminates for roughly a second then goes out. there is a screen on the handle bars which feeds information to you, this would start up as if it was powering on when the power button was pressed but turns off after about 5 seconds. i tried numerous things like making sure the cables were plugged in wherever i could see them and pressing and holding the power button but nothing would work. i left it on charge over night but again the same problem the next day. im sure the bike was charging as when i plug the bike in the power block on the charger would illuminate orange.
I hope someone can help!
Dave_h34
78
42
Warwick
Keep looking at the battery. When the main display screen goes off, do you get a flash from the green lights on the battery? If so the combination of leds lit will give you a clue. Explanation in the user manual.
Paddy
Chester
Hi Dave I will have a look. I didn’t notice anything but I wasn’t looking for it. Thanks
9,259
When the bike has been off for a while (an hour or so) it will need two slow presses to get it going, otherwise only one. If too soon, two presses will turn it on then off again. You will get a variety of flashes.
If the above fails, try holding the power on button down for at least 10 seconds, Its known as a hard start. Its not in the manual, but one of the guys at the Sherwood Pines bike shop told me about it. He had never tried it on a Shimano before, but it worked!
Nautonier
51
20
Melbourne
I have a very similar issue with my Range VLT, which stopped working yesterday after 10 months of frequent riding and no issues whatsoever. When I push the power button, the light comes on and then slowly fades out. The display does not come on at all. I have tried the 2 x slow presses and the 10 second long press, but it just won't boot up. I took the motor and battery out of the frame and all the connections look to be fine. Is it possible that the motor has simply died? Would the display come on if the motor was dead?
Paddy
Chester
Thanks steve i will try this
Nautonier
51
20
Melbourne
Hmmm. Suggests battery ok then. Only leaves motor or cabling.
Yep, the cable does look like it's been kinked at some point, so maybe has finally given up. Just wish it was an easy thing to get hold of a new one and test it... I reckon it's that, the power switch itself or the motor.
Jun 30, 2020
uk
What was your issue in the end??
socalty
Orange County, CA USA
I also have same problem after botched fw update. can connect tho everything except the battery.
Bike shop just informed me that my ebike start issue was due to the remote power switch. The switch has a battery that if its level drops below 30%, disables the switch. The main battery charges the switch when riding. The bike shop had to reset the firmware in the switch to have it recognize that it’s being charged. Not sure how the switch’s battery dropped after only 2 weeks off bike. If it continues, shimano will replace it.
HoosierFDaddy
'Murica
I have reset firmware on the motor, the remote switch, and the assist switch through direct connections. I can't update the computer because the pc app tells me there is an update but it's incompatible with Bluetooth LE, update via the mobile app. the battery is not being recognized by the app and only activates anything upon insertion then cuts off. and how could you charge the remote switch battery while riding if it doesn't turn on. odd design.
socalty
I agree it’s odd to have a power switch that requires separate power to function. I’d be ok with a light switch, but I’m sure shimano had better ideas.
My bike shop indicated that they had to reset the power switch firmware multiple times before the switch would recognize that it was being charged by the main battery. They didn’t mention needing to reset firmware anywhere else. That’s all the info they provided…keep us posted if you get your bike working.
HoosierFDaddy
'Murica
I had to reset everything else because of the bad upgrade. I'll try the power switch a few more times. I will definitely share if I get anywhere with it this weekend.
OJMad
Hello
I have a similar though not so drastical problem. After 2 years, both, my wife`s and my Merida e-one sixty only start by switching it on directly on the battery.
We can shut the bikes down by clicking the the normal switch. But when trying to switch the bikes back on, nothing happens. Keeping the switch pressed makes it blink every second.
Anyone ever having this problem too?
Might this need a reset of the switches by a servicepartner ?
77
41
Tucson, AZ
I know this is a bit of a thread revival but I suspect more and more people will be stumbling onto this issue in the coming future. I just dealt with it myself so hopefully more people can find this thread.
If you look through the manuals for the Shimano EP8 system it mentions nothing of this battery in the power switch (and the exploded parts diagram on Shimano's site shows it as an assembly so you can't see a battery in there). I stored my bike (equipped with EP8 system) for about a month and half and recently when I went to ride it for the first time again I couldn't get it to power on even though my battery was showing full charge. Fortunately the bike shop found this exact thread and was able to solve the problem by charging it through the PC dongle.
The manual really should make a mention of this, really all it says is to store the MAIN battery around 70% and not to let it discharge too low so you should keep the battery topped up every couple months or so via the charger. The problem is the battery in the satellite power switch only charge when the bike is powered on, so it will not stay topped off the main battery when the bike is powered off. So you really need to leave the bike powered on every once in awhile as well to ensure the power switch battery doesn't die... Seems like a silly design.
I know this issue probably isn't a problem for many people, but if you live in a state that actually experiences winters where you might not be able to ride for long periods of time; I feel like this issue will be cropping up a lot.
I also found a couple threads where people mention that the EP8 display also has an internal battery but have not been able to confirm.
James1290
Essex
Hi all,
Can someone clear something up for me. Is the Shimano On/Off button meant to stay illuminated when the bike is switched on and in use?
My button is working at the moment when powering the bike on and off, but the green light fades out a few seconds later after the bike has been turned on.
Just wondering whether it’s meant to stay illuminated during the whole use of the bike or if the battery is dying, hence the light fading out.
Thanks,
James
Scm90
United kingdom
Hi all
Just found this thread and hoping for it to be a life saver….
Have a 2022 Heckler which doesn’t want to turn on. Darfon smart plus charger is flashing orange which obviously means error, the battery appears to be charged and I’ve tried it in and out of the bike. When you press the battery to check the charge it flashes 1x bar a few times, then full bar, then every other bar before stopping …. Strange.
Reading above, the switch battery rest sounds interesting but how are you meant to actually do this with your laptop? Simply connect a usb c or do you need a shimano adapater kit like the SM-PCE02? Does it work with a mac?
Any help appreciated! I’m guessing it’s the switch as the charger is fairly new… bike is hardly ridden too.
Jamie78
Campbell River
I just had the power on issue on my GT Amp (E8000) and after a bit of hunting found this... Shimano T.E.C.: Log in to the site. You need to register an account (can name any bike shop as your 'employer') but this descibes exactly the switch issue and what you can do about it. Straight from Shimano...
I couldn't get into the Shimano site as you need a shop number from Shimano as well. Any suggestions to bypass this?
552K
