Shimano E8000 Chainring
UKEMTB
Hi,
I have a Mondraker e-bike (2018) which has an E8000 motor on it, I am wanting to change the chainring on the front but not sure on exactly what is needed, can just the 'outer' ring be replaced or do I a direct mount style, here is a link to the two I am looking at:
Here is a pic of whats on the bike, sorry the quality is crap but its the only pic I have on my phone at the min!
raymal
39
17
Southampton
Hi,
The first one (without attached spider) is the one I'd go for. Check out different makes though as prices vary considerably - I've just bought a Race Face for sub £30. Just bear in mind, depending on how easy it is to remove the chainring/spider bolts, you might need to remove the cranks and spider locking ring to release the whole assembly and that requires a lock ring removal tool - nothing's easy!
20,749
From what I remember most 104 BCD chainrings will fit. You only need the outer part. You might have to take a pedal off to slide the old one off/new one on.
If you increase in size, make sure there's space and it won't hit the rear triangle and that your chainguide has enough space to move further up.
luna87824
434
1,169
Just South of The Grand Canyon
e*thirteen by The Hive e*spec Aluminum Direct Mount Chainring 34t for Shimano E8000, Black
552K
