Hi all
So went to remove the drive side crank arm and intitially the self extractor was tight, then lossen and remained loose without moving the crank arm. I removed the 10mm cover cap and sure enough the self extactor threads are stripped. I suspect they were damaged by the previous person who worked on the bike as i used very little force to undo it.
So does this mean a whole new motor? Or can the axle be replaced?
