Santa Cruz Ebike
Hitby
182
169
North Yorkshire
Had a good look at one of these today at BikeScene. It's a really nice looking bike. Apparently there's been a lot of interest - £7.7k though!
AZRickD
62
60
Arizona
The low camera angle was a necessary evil for my purpose.
I wanted to show the pedal movement vis a vis the motor.
I suppose I could have swapped views a bit for those more interested in the scenery. ;)
Raining in Phoenix today.
Epic riding conditions (moto and pedal) tomorrow.
Doomanic
🛠️Wrecker🛠️
8,824
10,573
Yeah, it’s like the “Sam Hill uses flats so everyone else should” argument. Danny Mac isn’t normal.
There’s a good video out there of his first ride on the Heckler and while he was getting used to the extra weight it’s not all successful tricks by a long shot. Still way more than I’ll ever be capable of though.
Fivetones
898
905
Cheshire
I love the little brake chirrup noises he makes when surveying each section. You can just feel the vibe he has from vids like this. Such a class trials rider.
AZRickD
62
60
Arizona
Approaching 300 miles on my Heckler-S.
No issues on the Heckler.
Using STUNLOCKER, I reduced the wheel size by a metric factor of 0.62. I now get 28-MPH in Eco and about 32-MPH in Boost (apparently the new limit). I flipped the display to read KMH which shows a facsimile of the actual MPH (due to using the metric factor of 0.62 to reduce wheel size, don't ya know?). Mainly it removes that annoying power drop-off that begins at 18.5-MPH (right when I really need it).
The Shimano E8000 really doesn't like the pedals spinning up much beyond 120 RPM. It drops of the power very quickly. I'm a spinner and use lower gears a lot, but on those quick sprints up a bump, I'll have to run a gear or two up.
I found that I wasn't getting enough suspension throw. The last inch and a half (40mm) was evading me. So, finding three spacers in the fork and two spacers in the shock, they were removed with prejudice.
I'll test them on my rocky local trail when the mid-week Phoenix rain soaks in a bit.
Steveg56
8
8
California
Hey AZRickD,
How did you remove the spacers? Is it difficult? I’m 195lbs, do you have any idea how many I would need in each front and rear shock? Sorry new to this mountain bike thing. Just purchased a new Heckler CC S model last week.
losgatosgtr
188
153
Los Gatos, California
Levo SL has a max tire size of 2.3", and that's a non-starter for me. I need more of an all-mountain bike. I'm quite happy with my Shuttle for now, and will wait it out a year or two for the next wave of drive and battery systems that don't compromise range and power for weight.
I have the SL and you can easily fit a maxxis DHR II in 2.5 with room to spare. Many other 2.5 as well.
AZRickD
62
60
Arizona
Token removal is Easy Peasy on the Fork. The shock is similar only different. Search YouTube.
I removed them all since I wanted plushness to be king to my aging joints. There is a chance that I might have to add spacers back in (maybe to the shock if it doesn't ramp up to my liking), but I'll ride it through some rough stuff for a while.
For the Fox Fork:
For the Rock Shock Shock:
Gary
Old Tartan Bollocks
10,496
10,706
the internet
I don't really see how?
The Sam Hill argument is "Sam Hill WINS on flats" "so why do you (other top pro racers) *need* clips"?
In the grand scheme of things. No matter how skilled the rider, trials looks a bit shit on an E bike. For the same reasons it'd look a bit shit done on any bike aproaching 50lb in weight.
Gary
Old Tartan Bollocks
10,496
10,706
the internet
The Sam Hill argument is "Sam Hill WINS on flats" "so why do other top pro racers *need* clips"?
In the grand scheme of things. No matter how skilled the rider, trials does look a bit shit on an E bike. For the same reasons it'd look a bit shit done on any bike aproaching 50lb in weight.
Jim25
91
51
London
What like an actual trials bike?
akuria
135
58
san francisco
Can you show a screen capture of your STunlocker? Currious on the .62 reduction. wouldn't you want to increase not reduce? I know with my truck I have bigger tires than stock so my speedo is 9% off meaning if it says i am going 60 I really am going about 64-65ish.
AZRickD
62
60
Arizona
This is not experimental. It has actually been done. Results verified with GPS.
If your wheel setting is 2200mm (on a 27.5" rim), multiply that times 0.62. That will give you 1364mm. Change your wheel size from 2200-ish to 1364-ish.
So, when your wheels are spinning super fast, the computer will say, "Well, duh. He's spinning teensy wheels. Party-on, Garth."
Change your display to read Km/hr and you will have a representative read-out for MPH.
564K
