It's time that I replaced the routine parts on my 2020 Turbo Levo Comp. Please could I have some advice on which are the best replacement parts ? Price isnt really important ( within reason of course). Im tempted to change like-for-like but even then I don't know which ones to get
A little bit about me would help probably:-
Bike: 2020 Turbo Levo Comp - Medium
Age: Ancient, 65+ (Me, not the bike)
Weight/Height: 80 kg/1.79m
Shock/Tyre settings-- as per Specialized calculator
Style: None
Fitness: Please refer age
ZF- Tank Commander Scale: Snail with fragile shell
Temperament: Crazy, more money than sense, Love my newfound passion.
Experience: More than most -- irrelevant here though, only MTB-ing since May 2020
Features: Big grins, bad language
Stomping Grounds: Primarily South of France so far but also Switzerland
Terrain: in first 1500km (since end May, Id estimate 75% paved road, balance steeper fire tracks - primarily stones and rocks as well as forest trails - mixed surfaces. Likely to get different / higher / grassier challenges over winter 2020/2021.
Values: Reliability important, performance next.
Derailleur Hanger
Might as well replace as Ive bent once. I'll get 2 -- all seem to be the same online using Specialized Part Number. Am I correct?
Brake pads
No idea. Ive read so much but all I know is sintered .. so many makes out there.
Chain
As per original or is there a better, more reliable option?
Tyres
The more I read, the less I understand about the right general tyre choice . Generally been happy with the stock tyres but I see the criticism on here so if better exist Ill use them. My only issues with Butchers is the front 'scrubbing out' when transitioning from hard packed dry earth on to travel stones during a corner. Happened several times but may be the rider of course. Ive had wheel spin on very steep stony/rocky climbs. I have no wish to change the rear wheel size .. just which are best tyres for me? Rear is getting a bit 'slick' in the middle now. Wear is very obvious.
Grateful for all help on the above. Anything else I have totally missed ? Thanks in Advance.
Style: None
Derailleur Hanger
Brake pads
Chain
Tyres
