RockShox Super Deluxe Coil
TX1911fan
9
Austin, TX
I searched and could not find the answer I have been looking for. Can someone help?
I want to buy a RockShox Super Deluxe Coil shock for my Decoy Pro Race. My shock size is 230x65. WIth RS, you buy the spring separately. When I go online to look for springs, I see numbers listed for length and travel. For example, on JensonUSA, there is Length 174mm Travel 67.5-75mm, or there is Length 151mm Travel 57.5-65mm.
My question is this: do I just buy the spring rate I want with a spring that does 65mm travel and the length is correct? Or do I need to find out what length I need too?
Thanks!
Sapientiea
296
192
Netherlands
I'd whish I could answer your questions, but I have literally zero experience with coil shocks. I was thinking about switching also, but do not know where to start :(
Shog46
100
74
Yorkshire
My rear shock is the same size as you are considering, hope the photo helps
552K
