Rise rear brake change hose routing
Benjimax
33
16
U.K.
Hi folks
Has anyone replaced a rear brake on a Rise? Wondering if the hose is routed through internal guide tubes or if its a motor/battery out job?
Thanks!
Shjay
835
491
Kent
No internal guides & dropped the motor don’t need to remove battery. Its a pain to do! if you can keep existing hose I would, I sold the brakes on complete
Benjimax
33
16
U.K.
Awesome thanks for the quick reply. Didn't think about keeping the hose, good idea. Limits you to shimano and possibly magura I guess
b33k34
281
103
Much easier to remove the battery (and very simple to do - it's only two bolts) and with it out it's very easy to route the hose. Many/most brakes now come with the calliper connection crimped on. routing through the loop over the motor housing and through the chain stay was more of a pain.
I used a length of unused hose and a reverb red barb to connect. fed through the 'empty' hose pulling on the calliper and fed through the new (SRAM Code) hose the other way, using the empty hose I'd fed through to guide the new one back,
Benjimax
33
16
U.K.
Great thanks. Think it all sounds a bit involved removing motors and battery so I think I'll stick with shimano and upgrade calipers on the m20 to 4 pots
GMLS
336
209
I'm expecting to do the same when mine arrives as I'm used to Magura MT7's but have you tried upgrading from 180mm to 203mm rotors first?
Benjimax
33
16
U.K.
Good shout. Haven't tried as waiting for mine to arrive too :) the m10 I demo'd had 180mm plus xt's and I quite liked that combo.
hugoagogo
8
How do,
I cut the head off a small screw and used it to join the 2 hoses together and pull the new one through from the headtube to the rear caliper. No need to drop the motor.
Wild-Fins
14
SoCal
Running Magura 220 rotor front 203 rear with custom MT5s
I'd like to upgrade the rear rotor to 203 as well but don't know how with the magnet sensor.
Would you mind elaborate how you did it? Which brake magnet to buy and how to install it on the new rotor?
TIA
Shjay
835
491
Kent
TIA
Is your bike an M20 or M10? The M20 then need a Shimano RT-EM810 203 centrelock rotor, M10 then can remove magnet that’s attached via the 6 bolts holding the rotor to the wheel & buy any 6 bolt 203 rotor, also need a 20mm adapter that spaces the rear brake higher to compensate the 20mm increase in rotor size, otherwise take to your local bike shop
576K
