Rise Hydro Shock Mounting Hardware
BumblebeeTuna
14
Bay Area
Where can I buy a new set of shock mounting hardware? I understand M8x21.84 and M8x16.5 are the sizes I need and I have been looking but can't find the 16.5 yoke side hardware anywhere. I recently bought a new DVO Jade X and would like to have the option to switch between the Fox Float X that came on it and the new one without removing and installing new hardware each time I swap.
Thanks in advance!
BumblebeeTuna
14
Bay Area
You can order hardware from offsetbushing.com...they sell Standard hardware w/o offset.
Thank you! I just ordered them. Apparently the yoke side is proprietary to Orbea so I couldn’t find a replacement, but it comes out and installs easily so no bid deal.
Funks
84
49
Dublin, CA
For the RISE Hydro, see below.
Frame side - 8MM x 21.84mm
* Fox Hardware (IGUS Bushings) - Fox (803-03-279)
* Rockshox / Manitou (for DU Bushings) - RockShox (11.4118.091.807)
Yoke side - 8mm x 16.5mm
* Fox Hardware (IGUS Bushings) - ?
* Rockshox / Manitou (for DU Bushings) - Fox (803-03-062) - 8mm x 16.4 for DU Bushings.
552K
