ian6354
Bike has had very little use, only selling as I also own another Levo. The bike had a full invisiframe installed from new including forks, cranks etc. The bars, stem, wheels/tyres, dropper/lever are all new as I removed them from new. I have a Specialized bike box which can be used to send the bike if required. Any questions just ask. Price £4500 Payment via bank transfer. Frame FACT 11m full carbon, 29 Trail Geometry, Integrated down tube battery, enclosed internal cable, Command Post routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel Rear Shock Fox Float DPX2 Performance Elite, 3- position adjustment, 52.5x210mm, Rx Trail Tune Fork Fox Float 36, Performance Elite, Grip2 damper, 150mm, 51mm rake, HSC, LSC, HSR, LSR, Kabolt axle Stem Alloy Trail Stem, 35mm bar bore Saddle Bridge Comp, Hollow Cr-mo rails, 155/143mm Handlebars Specialized Trail, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 30mm rise, 800mm, 35mm clamp Grips Deity, Knuckleduster, Black Rear Brake SRAM Code RS, 4-piston caliper, hydraulic disc, 200mm Front Brake SRAM Code RS, 4-piston caliper, hydraulic disc, 200mm Shift Levers SRAM X01 Eagle, trigger, 12-speed Rear Derailleur Sram X01 Eagle, 12-speed Cassette SRAM XG-1275, 12-speed, 10-52t Chain SRAM GX Eagle, 12-speed Crankset Praxis, forged M30, custom offset Chainrings SRAM X-Sync Eagle, 94 BCD, 30T Front Hub Roval, sealed cartridge bearings, 15x110mm spacing, 28h Rims Roval Traverse 29 Alloy, 30mm inner width, hand-built, 2Bliss Ready Rear Hub Roval DT Swiss 360, 3-pawl design, SRAM XD driver body, 12mm thru-axle, 148mm spacing, 28h Front Tire Butcher, GRID TRAIL casing, GRIPTON® compound, 29x2.3" Spokes DT Swiss Competition Race Rear Tire Eliminator, GRID TRAIL casing, GRIPTON® compound, 2Bliss Ready, 29x2.3" Inner Tubes Standard, Presta valve Seat Binder Specialized bolt-type, alloy, 38.6mm SeatPost X-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SRL LE lever, 34.9mm, S: 125mm, M/L: 150mm, XL: 170mm Motor Specialized SL 1.1, custom lightweight motor UI/Remote Specialized TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, w/Handlebar remote Battery Specialized SL1-320, fully integrated, 320Wh Charger Custom charger, 48V System w/ SL system charger plug Wiring Harness Custom Specialized wiring harness w/ chargeport |
