Sold 2021 SPECIALIZED LEVO SL EXPERT CARBON XL CAST BATTLESHIP/BLACK LEVO SL XL: 4800
fragledoozer
99
51
southport
Bike / Product Year: 2021
Manufacturer: SPECIALIZED LEVO SL EXPERT CARBON XL CAST BATTLESHIP/BLACK
Model: LEVO SL
Size XL
Asking Price: 5500
Location SOUTHPORT
Description Levo SL Expert Carbon
Finished in cast battleship/black
XL
Purchased in 2021 June for £8500 from wheelbase in the lakes (reciept included)
Very light use and low mileage
Invis frame from new so in mint condition
I will put actual pics up tonight
£5500 buys her
FrameFACT 11m full carbon, 29 Trail Geometry, Integrated down tube battery, enclosed internal cable, Command Post routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel
Rear ShockFox Float DPX2 Performance Elite, 3- position adjustment, 52.5x210mm, Rx Trail Tune
ForkFox Float 36, Performance Elite, Grip2 damper, 150mm, 51mm rake, HSC, LSC, HSR, LSR, Kabolt axle
StemAlloy Trail Stem, 35mm bar bore
SaddleBridge Comp, Hollow Cr-mo rails, 155/143mm
HandlebarsSpecialized Trail, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 30mm rise, 800mm, 35mm clamp
GripsDeity, Knuckleduster, Black
Rear BrakeSRAM Code RS, 4-piston caliper, hydraulic disc, 200mm
Front BrakeSRAM Code RS, 4-piston caliper, hydraulic disc, 200mm
Shift LeversSRAM X01 Eagle, trigger, 12-speed
Rear DerailleurSram X01 Eagle, 12-speed
CassetteSRAM XG-1275, 12-speed, 10-52t
ChainSRAM GX Eagle, 12-speed
CranksetPraxis, forged M30, custom offset
ChainringsSRAM X-Sync Eagle, 94 BCD, 30T
Front HubRoval, sealed cartridge bearings, 15x110mm spacing, 28h
RimsRoval Traverse 29 Alloy, 30mm inner width, hand-built, 2Bliss Ready
Rear HubRoval DT Swiss 360, 3-pawl design, SRAM XD driver body, 12mm thru-axle, 148mm spacing, 28h
Front TireButcher, GRID TRAIL casing, GRIPTON® compound, 29x2.3"
SpokesDT Swiss Competition Race
Rear TireEliminator, GRID TRAIL casing, GRIPTON® compound, 2Bliss Ready, 29x2.3"
Inner TubesStandard, Presta valve
Seat BinderSpecialized bolt-type, alloy, 38.6mm
SeatPostX-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SRL LE lever, 34.9mm, S: 125mm, M/L: 150mm, XL: 170mm
MotorSpecialized SL 1.1, custom lightweight motor
UI/RemoteSpecialized TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, w/Handlebar remote
BatterySpecialized SL1-320, fully integrated, 320Wh
ChargerCustom charger, 48V System w/ SL system charger plug
Wiring HarnessCustom Specialized wiring harness w/ chargeport
577K
