Rear Shock Replacement
Mik3F
129
123
Middleton
Can anyone who has the Gen 1 SL and a Fox Float X2 give me a simple guide on how to fit it, or anyone who knows how to fit a rear shock for that matter
I have a 2022 Float X2 on its way to me that came from a Turbo Levo (2019)
I assume the bushing will be fine for the SL or will I need to remove the ones from my current DPS shock
Hoping its just a case of unbolt the old one and bolt the new one in and torque to spec (10.2 and 23.7)
Flip chip is just a straight reinstall? Is it easy to determine which orientation it is set to (High or Low)
Cheers
SP SUSPENSION
7
Scottsdale, AZ
Cheers
Should fit no issues. Just swap the mount hardware over and go. Set sag at 30% of stroke (16-17mm IIRC)
526K
