Jim c
What tool is needed size wise for the cassette on the 2020 levo my two halves move so need tightening up
Just as a tip, don't use the chainwhip backwards like that guy does unless you want to knacker your cassette. The fixed chain on the tip is to grip the cassette and the loose chain wraps around to hold it.
Here's how to do it properly along with a little bit of info on the cassette tool types.
You may have to pull off the axle end cap first!!The trouble is my tool looks to be the correct spline pattern but wont fit over the sodding axle so im buggered
