Protective tape
Silato
128
73
Manchester UK
Hi.
Has anyone used clear repair gorilla tape to ptotect there bike frames.
Looks similar to Hele tape but was looking for any info on others using it.
Thanks.
9,269
I haven't used Gorilla tape for that purpose. I have no idea how protective it is against impacts and surface abrasion, it looks thinner than even the thinnest heli-tape I have been using. But it may be quite good, I dunno because I haven't used it. Why not give it a go and report back? :)
If ever you want to remove the Gorilla tape, be prepared for a battle, after all it is an adhesive tape with aggressive claims. By contrast heli-tape comes off quite easily, followed by a wipe over with IPA to remove any residual adhesive.
Gorilla tape is superb when used as rim tape for tubeless tyres. Compared to the rim tape I have had to remove, it performs on another level entirely. :love:
mark.ai
828
594
Windermere
I've used some clear gorilla tape just where my front mudguard is zip-tied to my forks - it works great there as you hardly see it.
I wouldn't use it on a larger area though, where it is easily visible, as it seemed impossible to get on without bubbles forming underneath. Maybe I was just crap at putting it on, as I was doing a quick job for the mudguard :)
Also not sure how it will work on paint - e.g. when you remove it - as the Gorilla tapes are all extremely sticky.
Mattwilko92
229
188
Staffordshire, UK
After messing with various bits of helitape over the years, i dropped my new Levo off at Invsiframe this morning and they did the frame, forks and cranks for a very reasonable price. The quality difference is night and day compared to when i’ve had a go
Kernow
1,436
1,149
Cornwall uk
Yes I bought a Role of clear gorilla tape the other day just for that purpose , it works very well , it’s been on a new bike that gets lots of hard use and it’s staying put in the places where the normal invisitape would lift , I recomend it and at about £6 for a decent size roll it’s cheaper
9,269
I discovered that when helicopter tape is applied to a green or red or blue gloss finish bike, you can't see the tape from any further away than 15"-18". :love:
But on a black satin finish, it looks like there is a layer of condensation underneath the tape, and it looks vile. :(
The lesson is to test an area first before doing the whole bike. :unsure:
Tim29
421
549
Left the building
3m makes a great clear vinyl called moto guard.
You can buy it in large sheets.
I use it on bottom bracket and down tube. Works great and u can get it up to 3m thick.
It comes off pretty easy with a heat gun
552K
