Protect frame bearings from road salt
steevwatson
7
GB
I've been using my old handrail emtb to commute to work but it has been stolen. I need to cycle to work for the next couple of months on my Orbea rise. Is there anything I can do to protect the linkage and bearings etc from road salt over the winter. I've got a decent fenders so they cute down the spray a bit. Would it be worth taking the linkage apart and putting some grease on the outside of the bearings to keep as much water out as possible? I also have come Muc off HCB-1 where do you recommend I spray it? I will be replacing all the bearings in spring and I have an old drivetrain on that will probably be toast after the winter anyway but I'll keep it cleaned and wet lubed. What are your thoughts?
Alfmeister
23
17
Uk
Maybe use rust blocker XCP Professional, as used on motorcycles and found it to be very good. The main thing is to hose off the salt with cold water, and dry the bike. It’s a little like ACF50, but not as messy. Obviously don’t get it on tyres, brakes, hand grips and peddles.
562K
