DaveNewing
This is a bit of a long explanation, but I don't know a short way of explaining the issue I'm suffering with. I have a 2020 turbo Levo and about a month ago I couldn't turn the bike on with the TCU power button. If I disconnected the power cable from the battery and then reconnected it, the bike could then be turned on with the TCU power button. The issue I noticed was when I turned my bike on using this method I would get a red LED flash twice before all the power bars light up. The red LED was the lowest one on the TCU display. None of the fault codes from Specialized show this fault so I contacted my Specialized LBS. I booked it in to diagnose the problem but I had to wait nearly a month before they had any time to look at it. They told me the fault was with the TCU itself, but in the month I waited for them to look at it they were no longer a Specialized dealer so they couldn't order the spare part. I ordered an new TCU from a Specialized dealer and it arrived today. My LBS said it was a plug and play part so all I had to do was register it with my Specialized phone app. I fitted the new TCU and paired it with my phone. I adjusted the power settings to my liking and thought everything was good. I turned the bike off and tried to turn it back on to check everything. The bike wouldn't turn back on. Even disconnecting the power cable from the battery and reconnecting doesn't solve this problem. I can only get it to turn on if I remove the TCU from the frame and disconnect both cables, then reconnect them again. This will allow me to turn the power on once, then I cannot turn it on again.
Any ideas what is wrong?
