Damp on the TCU
Paceman
92
59
Brighton
This is what my Spec shop spray on all the contacts and TCU when a bike leaves the shop ... they have not had any returns ..
eBike Ultra Corrosion Defence 485ml
guy told me it creates a thin film that stops water getting in .... Snake oil ? perhaps ...but worth trying.
Might be useful around the TCU connections, i'm not sure i'd spray it on the battery terminals though; isn't the advice to keep those dry as possible.
Any other shops / workshop techs using this for Levos/Kenevos?
20,848
I only had lubricated condoms, so I made a gasket and sealed my TCU with Sugru instead:
Zk-7D4D24239pbblYWa6e72jlukRTaYZINGAGRG9eXsDqBmsGeUCHR4dS0SpqQ1rGlxvlA2nS16uwHfDxEsQfT05tWLcYY5X5vDMTNORvFysRYeC7CcsHY4zHAQApeWam56j4pibWsHdhR3eRdlO4edUuqct6yBQwibXwpG1u0INvbzE_jD1IICP4jOI8KU-CWaCAPXg2PTls3YUzTWxbSUOiXN7YKFv2W4QPe5UCvkEBJQEa490NM_RPl6JCUOvy6gp0Owde71WU_t1e0-MP2yNBni8ZjrBRj3SYgYTIPU2d9wS-pwVVQXXi9VZs4CCZVSy7ReSvLdwIiQzKt1F4n8vz7J-CTpOVutcDKEspfv2rJ2wYOQfoF_xB6S9Zxt7VAjdCNWC-UfESkBor4sM2nJAHe2zQGxAf9QEm-gUqjxdfgirdLiXwUwQWfudXh2NkGaSiNwlI3Wj2HA1JptcW1ScklGuAv5GOY0L5iZZj3x3jqHw53fghyAU0rRmJN_KpY5ZQeMqfxSE4_c7aFEtwYwUxrUelW4bHWDTWBGMzAc-xUlFnBuxnEu7b5aLiJ4uHOdB5M8UPo0GrZruafOLjZGbNATCuWUSCQXzrUEbFYaJH1_r92PxD_E2GOJKSTmKfgVj3TiYZq6jN3hZMMsh7dolhSLzmFpX8A-bc8cfjEHZ3alBMus_c405=w3054-h1486-no
BOgBUE6bg9k-abo4uY03DsDl8vkeVLFNOZkF0xWtyl5_Ost3JhIlV088WrWv7yZAitcS7SFPbIFHJrWh-xNR3Av_RVUScgmpknyI2H0SnQSYblTqZhzF2sFh6lTrNAxYf-6gKcXlV5WGuxo7ZOyywkboYuCz4spxKMTjGmdIN9UWxEUJLssfeNC0s4EG8XAUWbOdFqQQuQHZApgwKYFFXTW3xZwXJQl8BHFhQQnz-VyNE2mmQvRowNOtkqcKxANZ1t1rmO_J31fCFq6iJ07wsWbhDd_BrnrwjpVCyuSrQly6ati_i00-NOKVxmmqxDs22gk2Ls14eD9b5na6UflpErswBrMTjCAilhclPSxDPibquEoaRxGzaKwb73h7MxxBbGM-_k0zApQ2Y1fwhJd276DSNy9XsNWKsMv1NvbzFmFdLrPF-R5IfYbB82zumkcTRr_yM6Fgfhm8qtnWATeDRLFJy2bboYhl8EjMzC-Dfrf0BrOsa-_uNvomk7SGVb-YeHtQDiGX-41p9P2pz6N4E7tCELOQsmWmJtjZjWNXYRlBnf4FbQklDWFzRIUJYnGY0y32O5eEgQ2MgMwunKKwCyPmjzmBz6qzOJHdLHoZ59k7v0HRu7GDeQofqtQZUNiC4eoNED1uWl9dNdYFXgmrcngz1MZgklsu4U-AOdwNyLotXhx8VUBKAdyo=w3054-h1486-no
Might just be, but I can't see your pictures. Sometimes if they're copy/pasted it maintains the source link so if they're not publicly viewable, you will see them, but no one else can. I normally download them and then add them using the insert picture icon. It's a faff, but works consistently ?
gmurad
87
70
Toronto, ON
Sorry, just fixed it.
DuncanDoughnuts
323
177
Cape Town/JHB/Rippon
could you not just put some silicon sealer on the tcu ? and where it screws onto the frame ? that way you can peel it off if you need to. Sugru seems like such a permanent solution .. ?
gmurad
87
70
Toronto, ON
I never had to remove Sugru before but my understanding is that it's easy to remove it completely.
JetSedgwick
384
1,005
Lake Tahoe California
For $3 duct sealant seems to be a good way to keep water out. Where the wires go in and out of the TCU, it can be worked into there much better than electrical tape. I also dressed along the edges of the TCU after I took the picture (arrow). It was easy to apply and can be cleanly pulled off also.
this seems like a great idea...is it working? I'd buy some of that if you think it is a good fit.
559K
