Pressure Washer ... is 25 bar too high?
stonedwolf
60
25
Glasgow
Yep, last couple of times I haven't needed it, trails even up here are drying out.
My squirt gun keeps disconnecting itself from the hose. I think I need to make a return if I can jury-rig a fix.
Paulcon
27
19
Cheshire
I’ve for the Worx Hydroshot, and a 10L Jerry can, so I can clean my bike before putting it in the back of my car.
The worx is a great option because it’s portable and only slightly more powerful than a garden hose, obviously I stay away from the motor.
RustyMTB
3,055
7,396
Utterly pointless. The motors get used In driving rain, mud, puddles and streams all the time. The front wheel fires water straight at the motor area. That’s what they are designed for. It’s not a problem. You’re not going to cause any issues sensibly washing it.
Surprising what you find, browsing this site. :unsure:
Growmac
384
451
Wilts, UK
Haha. I mean that's fair, but I'm unconvinced that washing the bike is worse than using it in the driving slop, which is an unavoidable part of UK biking over the winter. None of the bikes referenced above are pressure washed, but none are only used in the dry and then just dusted off either.
I don't jet wash the bikes by the way, I use this gadget to help get them clean. It works brilliantly, with almost zero water pressure at the bike.
antti86
16
22
Finland
I have kärcher OC 3 plus, 7 litres water tank. It's low pressure, but enough to get bike clean. I live in apartment building and store my bike on the living room, so this has been good solution for me.
surfperch61385
US
I try to avoid water as much as possible, id never use a hose to clean my bike. I laugh when I see off road vehicles that are polished top to bottom. Clean the parts that ought to be clean, remove what you can with a brush and a towel. Everything else just adds chericter. Show the world that you actually use your bike.
stiv674
777
600
Wiltshire
Bit late to this thread but I've been using the Norse SK25i for about 18 months now, was using a Mobi 17 for a year or so before that, never had any issues with water ingress.
Just need to be sensible about where you're pointing it, why would anyone fire it straight at the motor anyway! 🤔 oh and the Norse does have a lower setting.
576K
