Pressing + button and nothing happens
Keevan27
7
Brechin
Ok, quite new to the forum and new to Electric powered bikes, got myself a Levo Expert 2019 used, bike is immaculate but when using it for the first time and checking it over found that when I press the + button I am not getting any increase in power. I press the full power button which works instantly, I can decrease the power by using the minus button but when I press the + button there is zero change to the lights on the control panel or to the power?
Can anyone shed some light onto the possible issue?
salko
1,275
866
SLO
Sounds like your remote (+ button) is not working properly...
Pondboy
16
11
Mas de Barberans, Catalunya
The + button only works if you are in eco mode, where it puts you in Sports mode. Another push does not put you in Turbo mode (Well it doesn't on mine). You have to push the S turbo button for that. The - button does step you down through both modes to eco again.
Rusty
E*POWAH BOSS
Jul 17, 2019
1,513
1,673
New Zealand
On a 2019/2020 Levo a single push of the + button from Eco will give Trail and a double puch will give Turbo. If you don't get that, to me it sounds like a connector is not right - talk to your supplier.
KennyB
824
564
Taunton
Rusty is right. Owners manual will confirm this. By the way, in Eco, pressing - gives 0 support but system is still on and a press of + goes to Eco. Never used it.
Keevan27
7
Brechin
Thanks for the reply. Will call dealer tomorrow to see what the issue is. Pressing the plus button does nothing.
All Mountain Coaching
1,332
980
GB
This happened to mine. I had the motor replaced and it worked again. But mine was already not turning on/off by the button as well, first before losing the +
Keevan27
7
Brechin
Hi all, thanks for the comments, I had another look at it and when taking the item off and put it back on the system is working as it should now. So maybe a loose connection or cables being stretched on bars? (y)
552K
