Hi ! My emtb full suspension Scott Strike eRide 930 2020 edition needs a new rear hub, 2 new rims and spokes.
My rims are MD30 Syncross made by Alexrims, 29", 30mm width , tubeless ready, 32 spokes, pinjoint. The rear one has a crack after a inner tube explosion, so i am forced to change them.
My hubs are : front - Shimano HB-MT400-B, centerlock, 15mm x 110mm
Rear: Shimano FH-MT400-B, centerlock, Boost 12mm x 148mm.
For the front wheel i have already a DTSwiss hub
Please give me a good advice : two good rims (i preffer black and red combination), good spokes ( i read about Sapim, if you know something about them, i listen) and an affordable rear hub. My casette is Sram PG1210, 12 speeds . Thank you very much in advance for your help !
DT Swiss 350 Classic Front Hub - Centerlock - 15x110mm
but for the rear one i found also DTSwiss 350 hub who are to expensive for me - 160 euros, 3 times the value of the one for the front wheel. I am not prepare to do a great and expensive investment. I need to replace all that parts because i use my ebike almost every day.Please give me a good advice : two good rims (i preffer black and red combination), good spokes ( i read about Sapim, if you know something about them, i listen) and an affordable rear hub. My casette is Sram PG1210, 12 speeds . Thank you very much in advance for your help !
