this place is at 2k over sea level.I think we're at least about 2 weeks behind you. Windy and rain but no frost yet to make most tree leaves change colour and drop.
What width are those bars?Absolutely crazy ride today, punching well above my limit on the "Are you local" trail but survived to ride another day. View attachment 100230 View attachment 100231 View attachment 100232 View attachment 100233 View attachment 100234
Mmmmm your not the 1st to mention my lack of width ( bars ) but they are 760 !!What width are those bars?
It's probably an optical illusion, but they look like commuter width!
Thaaat's a lotta rock! Cool.
They look narrower (I said it might be an optical illusion). My current bike is 780, my last bike was 760 and the two before that were 740. In my opinion, 760 is a 100% normal width bar. My 5'9" 15-years old grandson has always preferred a wide bar and his are 800, as was his last bike bought when he was just over 13! I first went wide quite a few years ago now when I went from 660 to 720 and my first problem (imaginary as it turned out) was getting through the trees at Cannock (UK). Many of the tree gaps had gouges in them caused by all the wider bars hitting them at speed. My mate said not to worry as he had 740mm and he wasn't hitting them! My grandson got through there OK too, but I reckon the gouges had got deeper by the time he had a go.Mmmmm your not the 1st to mention my lack of width ( bars ) but they are 760 !!
What are the benefits of going bigger like 800 ? As I just feel it will risk clipping more stuff and my shoulders still haven't recovered fully from my last 2 offs lol.
Luckily only soft tissue damage that can be fixed by time. I’m not 25 anymore.. I think I am but, I’m not.So what did you break? Pics or it didn't happen
I'm happy with my 760's and can't get my stem any shorter lol that's why I have riser bars to centre me a bit more.They look narrower (I said it might be an optical illusion). My current bike is 780, my last bike was 760 and the two before that were 740. In my opinion, 760 is a 100% normal width bar. My 5'9" 15-years old grandson has always preferred a wide bar and his are 800, as was his last bike bought when he was just over 13! I first went wide quite a few years ago now when I went from 660 to 720 and my first problem (imaginary as it turned out) was getting through the trees at Cannock (UK). Many of the tree gaps had gouges in them caused by all the wider bars hitting them at speed. My mate said not to worry as he had 740mm and he wasn't hitting them! My grandson got through there OK too, but I reckon the gouges had got deeper by the time he had a go.
As for the benefits...
You will have more leverage to resist the deflecting forces exerted on the front wheel by rocks and roots. Consequently, your ride is easier and straighter and will feel smoother and less troublesome. There were some rocky downhill bends that I seemed to float through once I went wide. But the wider bars will move your body weight forward. That will contribute to easier climbing but bring you closer to going OTB on the descents. If that is something you discover that you don't like, then you may need to shorten your stem to restore your centre of gravity. Shortening your stem will quicken your steering. If you can't imagine that, then think what the steering would feel like if your stem was 200mm, then how it would feel if it was 20mm! A wider bar also puts your hands at a slightly different angle to the bars. Again, that may be something you like or not. Consider rotating the bars slightly to alter the angle. Still no joy? Then you may have to get bars with a different angle of sweep.
When I got my current bike with its 780, I thought it would be too wide for where I ride (mainly forest) and I was considering reducing to 760 because I knew that width worked. But I thought I should at least try it before such a drastic move. It worked OK and apart from having to do an occasional shimmy to get through the narrower gaps I have kept the width intact.
Still no pics? Thats really not good enough enuff. And yeah, my head tells me I can do stuff but my body doesn't comply. Getting older is not funLuckily only soft tissue damage that can be fixed by time. I’m not 25 anymore.. I think I am but, I’m not.
I like the no dropper.
