Hello
New emtb rider here and need some advice how I should handle this issue I´m having with Orbea.
I bought an Orbea wild and just after just 300km the whole cassette unscrewed itself from the hub and got jammed between swing arm and hub. Some minor damages was done to both cassette and swing arm. I contacted Orbea and they told me to bring my bike to a service point and they will sort me out. So I did, and they re-tightened everything and told me I´m good to go.
400km later the same thing happened. Back to the mechanics with my bike for another checkup. They swapped out 3 coggs that had taken damaged from when them unscrewed itself and got jammed. The service point told me my bike is fixed and I´m good to go ..
Less than 200km later same thing happened again. And the circle continues..
So I just picked up my bike from the shop again and this time they have used glue to secure both axel and locknut for the cassette. They told me there´s nothing else they can do for me since they cannot find the problem.
I´m having a hard time accepting glue as a fix for my 5.800€ bike. Am I really supposed to glue the rear axel every time I need to remove the wheel? Wait 24h for the loctite to cure before using my bike..
Orbeas own word said "In our opinion all the necessary service have been done so far" But in my opinion all they have done under the 4 months I´ve had this issue is re tightened and glued 2 screws. Not fixing the issue itself.
What would you guys do in my situation?
