Delivery middle of march6-8 weeks
Big difference ltd are the wheels 1400 grams vs 2000 g alluminiumSize Large with 360 battery, Fox 34 and DPS, aluminum wheels and tubeless tires: 39.67 lbs / 17.99 kg
Came with an EXO Dissector in the front (website says EXO+ but photos show EXO) as well as the "Lite" rear axle.
540 battery should add 800g according to all the reviews.
A bit heaver than I was expecting, I was hoping for closer to 38lbs. I'm sure we've all seen the photo of the 15.94 kg M-LTD. I have no idea how they did that, doesn't seem possible given the components. But these companies always lie about weights so I should be used to it
Robs 2023 M-team XL with 36 fork and Float X rear shock. 17.63 kg?! Selle kit carbonio saddle. Based on Robs measurements on his first rise M10 I needed a correction around +865 grams to reach real values.Size Large with 360 battery, Fox 34 and DPS, aluminum wheels and tubeless tires: 39.67 lbs / 17.99 kg
Not sure what you are asking. You are quoting the post where I stated the weight.did you weight your m-team when you got it?
Weight will be at least around 18.5 kg with pedals, mine is 18.1 with pedals and bottkecage but is with xtr and carbon wheels oquo (1550 grams)I have one coming a M team Large with the custom carbon wheels MC32LTD and 540 battery. Also curious about the exact weight? Was hoping to see the full review of Rob, but it’s already a few months ago announced and still no review. Let’s hope it’s still coming
I don't know what's up with Orbea's weights and those from reviewers. For the record, my 2022 H15 with a few upgrades and new 1750g wheels weighs 20.4kg without pedals tubeless.Mine arrived with tubes in there, so I removed the tubes.
So without the tubes, sealant and pedals, my medium frame with 540 Wh battery weighed 42 pounds and 1 ounce (~ 19 Kg).
I just re-weighed mine and this time also tubeless (with sealant), pedals and with CO2 cartridge+inflator in the head tube. Bike weighs 19.3 Kg. Again, this is for a '23 M-Team. BTW, I'm also using the Park Tool scale on the stand and not sure of all the weights all over the place.I don't know what's up with Orbea's weights and those from reviewers. For the record, my 2022 H15 with a few upgrades and new 1750g wheels weighs 20.4kg without pedals tubeless.
