Just sharing:
I have my Rise set up with two fenders on the rear:
I added the Mucky Nutz guard to protect all the lower stuff. It worked perfectly, barely a spot of mud in the charger area.
At first I liked that it was long enough to go below the chainstays (many of the others are not) but I realized that, because of the suspension design, this may not be ideal. The seat stay vs chainstay geometry changes as the suspension moves so it puts different stresses on the guard. The guard definitely rubs on the chain stay area. I ran a zip tie around the bottom of the guard and through the space between the BB and rear triangle, thinking it would help hold it away from the tire. This zip tie rotates as the suspension compresses so would certainly eventually wear through the paint (and maybe more!). I will remove zip tie, but the guard will still rub on that area.
I have the Mudhugger rear MK2 on order, which includes the extension to protect this area, but is shorter so it won't rub. The coverage doesn't look to be as good but will have to see how it performs.
- Mudhugger Rear Long fender (MK1)
- Mucky Nutz MugGuard, Short
