Personally, I prefer 2,6 over 2,8 and I found the 35mm perfect with 2,6.Yeah I like to try the 2.6 tryes because I been riding the width for a while now... But 2.8 just seems littie overkill...bike is still new so need to get used to it first... So what people thoughts with the 40mm and 2.8 over the 35mm 2.6??
Seconded. My stock Shimano hub blew up, and I changed to H1700 Spline 35mm internal. I'm not one for upgrading wheels until they're broken, but my god, the performance difference was incredible. Handling felt so much more direct, particularly if you're doing cutties. Expensive but worth every penny. Also has a steel freehub.I would get a wheel with steel freehub body. DT Swiss H1900 seems nice, or the H1700 if you want to spend more. You could also go H1900 (or 1700) rear and M1900 (or 1700) front to save 100gr. I would get the 35mm internal width version for 27.5x2.6 and 2.8 or possibly the 30mm internal for 27.5x2.5-2.6. I have been running a 29x2.4 front wheel for a few rides on a e168-800. Works fine, but need to use it more to decide what I prefer. I had to drop the handlebar a bit to get enough weight over the front wheel.
I can't find the eOne-Sixty 800e anywhere though. "e" usually is electronic shifting on the eOne emtbs. Sure it's not a eOne-Sixty 800?
