Box fresh, ready to roll
Weird that bike brands do this. There’s a few out there that supposedly should have correct HG+ hardware but they’re not using compatible drivetrain equipment.Also, the tranxXeP1, is not spec'd with a shimamo HG+ chain. Curious to hear your impressions of the shifting, compared to bikes fitted with the shimano chain.
Yes. Test and see. Mine shifts magnificently with an (Other than Shimano) chain, and I'm curious if you think a proper chain is even better?Weird that bike brands do this. There’s a few out there that supposedly should have correct HG+ hardware but they’re not using compatible drivetrain equipment.
Love the new cable routing. I am going to look at how hard it would be to make that work on my own MY20 as the cable routing is garbage and causes shifting and wiring issues. Good to see GIANT solution. Id love to see the battery contact plate if you woudnt mind?
Here is the TranXe battery contact plate.
Just had to change the shifter cable and jacket on my trance19 for the 3rd time. As soon as it gets any drag at all, the shifting goes to hell in a handbasket, even with a 10 speed.
Mine goes under the motor on the trance19. It still sucks, and takes every mm of the 2100mm cables I buy. New world hurts I guess.Thanks, no real change there then. Thought there might be some different moisture management To see.
same issue with my 20 on the shifter, sick of changing mine.
Routed it differently this time, sent it alongside the cover close to the crank instead of directly over the motor. It’s taken about 30 degrees off the worst angle.
Might help.
Stupid little issues these bikes have.... who thought that cable routing was acceptable? ?
very interested to see the review on this. Bought the 2020 model in May when bikes were like hens teeth. Been loving it and already looking for upgrade.
Grest channel, very informative
No, not considering a change, but I had it out and thought dam, this thing is stupid heavy.Are you thinking about replacing it by something lighter ?
And what about the whole bike, did you check how much it weights ?
Might help.
2-3 weeksI wonder what happened to this bike review? I couldn't find any videos about it on Rob's YouTube channel...
Opinions.Would be interesting to know how it compares to the 27.5 trance it replaces or even the slacker reign.
The battery cover, lower frame and under-motor cover looks a chunk better than the 2020 bikes, I was having a good look over the '21 bike in my LBS. Whether the wiring is any better in terms of being waterproof remains to be seen, but there is definitely MUCH more space around the motor for wiring and connectors. I was considering re-routing the shift cable on mine, but after some shifting issues with, I assume, ice forming in the cable I might swap the rear mech for an AXS and bypass the problem, along with a wireless dropper, because my current dropper is getting worse for wear now anyway.
Crikey, my dropper isn't THAT bad. It's wearing on the stem where it's been up and down covered in grit. I have read that they sometimes suffer from radial play.I would love to know how you get on with that. Just reading your idea has almost cost me money!!
Mine is coming apart tomorrow for new wheel bearings, pawls and springs and I am going to try the 2018 service kit for size in a 2020 dropper.
Not had one apart so no idea what I will find, but mine spins about 30degrees each way now.
Why wouldn’t it? It must be almost 6 months old after all. ?
Liking it! Suspension is very good, Maestro works very very well.I’ve seen on Strava you’ve ridden it........you cannot hide. Is it good?
