If so strange it was only 2 screw in the box or any washers because I bought all the parts and gave them to the shop.Looks like they didn't use enough washers. See my Levo SL (2021) with RS Lyrik, 40 mm Postmount and Centerline 220 mm rotor in comparison:
Yeah, that is f*cking horrible that really is.What a bunch of bodger's. Needs shorter bolts.
2022 Levo comp.
Just got my rotors upgraded to HS2 200 back and 220 front which also needed a 40mm post mount to fit the 220 rotor since original was 200 but it looks a bit strange - has the shop mixed the screws around or is it supposed to look like this?
Picture before and after.
View attachment 127341 View attachment 127342
Yes sorry I just noticed both are before. I only paid $18 for the job which is cheap in Norway so that's probably why they did a lousy job.Btw both your pictures are after. You dont need washers under the caliper with codes. Only guides have this.
Yes it's safe, but shockingly bad.
Like a bike shops doesn't have a pair of 25mm bolts it can sell you.
