New Garmin Edge with Shimano Steps integration
ebike17
10
Slovensko
And does the Shimano STePS EW-EN100 from the Garmin Edge 1000 work? Will I see all the information from Shimana Steps there?
stona1
20
9
Gdynia, PL
Hi,
I would like to inform that my Pinarello Andromeda 9.9 is now with clean cockpit :)
I removed E8000 display and using only EW-EN100 with EDGE 530.
Already done few rides an it work very well.
All credits to users of this forum, thank you :)
Arek
JonasH
169
104
Norway
Hi, got a edge 830, connection work fine but my bike is derestricted and Garmin grabs distance and speed from my bike, it fucks up the whole ride. Can I select that I want speed and distance data from my gps and NOT from shimano steps sensor?
Gary
Old Tartan Bollocks
10,496
10,705
the internet
Nope.
But...
There is a way round it...
Fit the Garmin speed sensor on your wheel so it overrides the bike's speed sensor data
You can also disconnect the garmin from the STeps motor completely. in the sensor settings
There's nothing much useful in the Steps data I'd want to display on a £400 fitness training/GPS unit anyway
JonasH
169
104
Norway
Nope.
But...
But i’d really like to have the battery % on display don’t need anything else...
Gary
Old Tartan Bollocks
10,496
10,705
the internet
Ah. Ok. have 5 lights on my external battery to (vaguely) indicate my battery level.
I take it you have an internal battery?
JonasH
169
104
Norway
I'm used to my Levo 2019 and Garmin integration via ebike IQ connect app. Gives me battery in % wich i prefere, aspessially when you only have 2 bars left, is it 40% or 21% (big difference) I found an old speedsensor and fitted it, worked like you said, Thanks!
Andromeda
8
Russia
I have the same bike as you! ) You can make your cockpit even cleaner. Carbon frame is transperent for Bluetooth and ANT+ signals, and Andromeda have enough space inside near the headset. You can remove the fork, put the EW-EN100 in and your Garmin will work. I use the EW-JC130 Y-split cable outside of the frame to connect both left and right shifters (I use Di2 rear derailleur). Love the way how my bike feels and looks now. :)
559K
