Need a new dropper post for 2019 Levo!
KennyB
824
564
Taunton
Hi Kenny I will see if I have the user manual for it and hopefully a numpty like myself can do it without messing it up :)
User manual no help on the how. This is what I wrote earlier:
Undo the threaded cap at the top of the lower tube, mine was really stiff and needed a plumbers wrench, I wrapped a piece of inner tube round it to protect it. Clean the tube and especially the inside of the cap, there is an o ring that sometimes gets stuck inside the cap. Press some light grease, I use SRAM Butter, into the top of the bottom tube and cycle the post a few times. Reassemble.
neils
213
116
Alton Hampshire
pretty sure the 2019 Comp (both alu and carbon) use Xfusion Manic so all this stuff about how to service Command posts is going to be rather confusing to the OP. I would suggest contacting Upgrade Bikes, the importer/distributor, as mentioned a couple of posts above.
Correct.... my bad... missed the bit about him having the Comp model.
randycpu
111
47
Silicon Valley, USA
When did your warranty run out?
I was told by Specialized that the Command Seat Post is NOT covered by the bike's warranty. They said these are a "service item" like brake pads.
On mine, the seal was sucked down into the gap between the inner and outer. It no longer functions. Needs a service.
But the shop said that the CommandPosts suck so bad that I should shop for a new one and not rebuild it.
Eduardoramundo
394
303
Glasgow
Seatposts are definitely covered for 2 years. My mate has had two.
Global Warranty Page | Specialized.com
neils
213
116
Alton Hampshire
if it is a Command Post you have then send it to PLUSH for a service. Then every ride give the stanchion a small coating, light quick squirt of GT85, action it up and down a few times and you’re good to go for a 3-4hr ride. I only run Command Posts both the 30.9 (x3) and 34.9 (x1) all work perfectly and have done for years.
KennyB
824
564
Taunton
I was offered a return under warranty of my X-fusion manic post. With the agreement of my LBS, ie warranty not affected, and since the upper seal maintenance is a monthly task, as well as being without the bike for however long it would take, I serviced it. As I described earlier, 5 min task.
By the way, I use suspension spray on mine, LBS also recommended it.
561K
