I have done nearly 500 miles on my my19 Levo Comp using tubes. In that time I have only had 2 punctures..one due to a thorn which only lost pressure when I noticed the thorn and pulled it out of the tyre...and the other on chicken wire fence! So no real incentive to go tubeless from the point of view of punctures but I always intended to go tubeless on my second set of tyres. Nevertheless I decided to give it a go with my existing ( stock ) tyres just to gain some experience beforehand.
I bought the Giant airtank which was a bargain at £32, and some Stans No Tubes Sealant. The wheels are already taped as standard and 2 tubeless valves came with the bike.
Given the tyres are used I first removed the tyre and tube and thoroughly cleaned both the rim and the tyre, then put the tubeless valve in. I used the method of seating nearly the complete tyre but just leaving a section on one side unseated, and poured in 100ml of Stans. Then fully seated the tyre. Connected the Giant airtank and released the lever. Done!
For anyone considering an airtank, the Giant does the job fine. Pressurising it to 160 psi with my track pump was a bit of a workout but doable. I was not sure how long to leave it connected so just waited for 3 "pops" and then disconnected it. As it turned out I could have left it a little longer because when I checked the tyre was only at 20 psi. I pumped it up to 33 psi with the track pump and then rotated and shook the wheel to get the sealant well distributed.
The only slight problem I experienced with the Giant airtank was getting a good connection on the schraeder valve to pressurise it. Giant have set the schraeder valve in a recess to protect it from getting knocked but the rather bulky presta/schraeder connector on my track pump fouled the sides of that recess. No big problem though. I reduced the height of the sides of the recess with a Stanley knife a few mm and the connection is now easy.
