deeph
Hi all,
New with E10 also it’s my first ebike frame. I have with M600 motor installed and actually bike looks good but haven’t ride it much though.
I have some questions in my mind,
deeph
- I feel like the PAS 1 is too powerful when it start, but after that with slow pedaling it feels smoother. I’m wondering, does DPC241 (bluetooth) display can change the settings?
- The battery door has opening about 1 - 2 mm on the lips. If I ride in wet condition, this likely water will come in the battery compartement. Should I close this gap or doesn’t really need to?
- What are sensors do I need to install? There are brake sensor and gear sensor I believe. I have the brake sensors but haven’t instaled it yet.
- Last, does the 13S 10Ah battery will have enough juice to run the M600 motor? I have 13S 16Ah with weight 3.9kgs, wanted more lighter setup.
deeph
