That's a design feature on the new 2.3 motor called "Le Mouse" - so you know it's working ..
@Bearing Man sounds like one for your expert experience ..
What was the ‘it’ you sprayed?i sprayed some oil in it now it sounds much better but the noise didn't disappear
Bigger chainring? Or is the guide on the wrong way?Watching the video a couple times it appears that the squeak coincides with when two arms of your spider pass under your chainguide. Could that be the cause of the squeak? Dry aluminum spider (or chainring bolt) scraping dry plastic chainguide? Just a guess.
Hello,
my turbo kenevo only has 650km and my motor already makes strange sqeaking sounds.
I made a short video.
Sorry I missed this one. We had a couple of weeks off work...Back on the case nowThat's a design feature on the new 2.3 motor called "Le Mouse" - so you know it's working ..
