I grabbed the 170mm fork and front wheel off my Pivot Firebird 29. Luckily, moving the spacers from the bottom to the top of the stem gave me the same bar height. I tried making the POS Marz fork better by installing a G2 damper, but I had to max out both compression adjusters and the pile-o-crap still couldn't bottom fast enough. After figuring out Fox 36 volume spacers don't fit(the Z1 is basically a re-badged Rhythm, with its 'cheaper'-thus thicker- stanchions) it, and finally finding out it doesn't even share the air-side with the Fox 36, I decided it was time to pull the ripcord and get a 36. Riding a lotta rock gardens, I've been kicking around trying a 29" front(at least) on my ('20)
Kenevo, so I figured since I have the forks and wheel on my Pivot, it'd be a perfect opportunity to try-before-you-buy, just in case it ends up riding like a rented mule.
It rained here today so I didn't get to try it out yet.
Anybody else been riding a 29" front(or both) through rocks, drops, bomb holes, yada yada?
