Any one out in Emtb land running Michelin E-wild tyres. Appreciate thoughts, pros and cons.
Cheers
Cheers
I ran one for a while on the rear. Good in the dry (but the DHR2 is better) fantastic when it's tacky, shite when it's sloppy.
If you do road riding on them, they will wear quickly but on the trails they last as long as any soft compound tire.Yes after trying most tyres I’m comfortable on the e wilds. Very good tyre they just don’t last long
Yes I ride to the trails near me which wears them down quicklyIf you do road riding on them, they will wear quickly but on the trails they last as long as any soft compound tire.
I notice most of the rider comments here are for the older, not newly released “Racing Line” version tires.E Wild Racing Line, new front and rear specific tyres from Michelin. Any one tried? Thoughts, comparisons?
MICHELIN MICHELIN E-WILD FRONT RACING LINE - - tyre | MICHELIN GB
I’ve been riding the 2.6
e-wild Racing Line Rear for about a month now after years on Maxxis 2.4 DHRll and find the added bite climbing and cornering a big bike (SC Bullit) is welcome although there is more drag pedaling… not my concern on e-bike.
I put the 'non E' Racing Line tyres on my bike on Friday to test out at the weekend.
I've been using the Wild Enduro F/R for years now, and wondered if the Racing Line version was any better.
It was a cracking sunny day for Scotland on Saturday... warm and dry, with the trails dry and dusty. A lot of my route was single track littered with big rocks and slabs... and the tyres were great. Good in the corners, and great grip on the tough descents. Impressed so far - but will wait until I've tried them in slightly slippier / wetter conditions before I make a proper judgement.
I think the E version is heavier and more robust (stronger casing) for taking the extra weight of an ebike.What’s the difference between non E and E versions of the Racing Lines. I’m guessing the answer is £10.
While at Sea Otter this Spring we spoke with couple Michelin factory guys about them… were told the casings are made for added weight ofWhat’s the difference between non E and E versions of the Racing Lines. I’m guessing the answer is £10.
So if I weighed 97kg on a non-eMTB (instead of the 77kg that I do weigh) would I need to use "heavier and more robust (stronger casing)"? Just asking.I think the E version is heavier and more robust (stronger casing) for taking the extra weight of an ebike.
Mine is under 17kg, so I can run the standard ones without any issues.
That really depends on your riding style (jumping, hucking), types of trail (smooth, loamy, or rocky, hardpack) as much as weight of bike.So if I weighed 97kg on a non-eMTB (instead of the 77kg that I do weigh) would I need to use "heavier and more robust (stronger casing)"? Just asking.
I think you missed the at the end of my post.That really depends on your riding style (jumping, hucking), types of trail (smooth, loamy, or rocky, hardpack) as much as weight of bike.
We have all types in our area so tend to go with sturdier casings such as Double-Down (Maxxis) Enduro (Conti) Wild Enduro, e-Wiild (Michelin).
Oh, I thought the wink was you looking for a date!I think you missed the at the end of my post.
Makes no sense to me either… same with ‘E’ rated suspension etc.So if I weighed 97kg on a non-eMTB (instead of the 77kg that I do weigh) would I need to use "heavier and more robust (stronger casing)"? Just asking.
