do you have to use the tokens that the shock comes with originally or are all the tokens taken care of in the megneg kit?My set-up in pretty much identical to Jester's.... 90kg, 295 psi... 2.5 positive tokens, 2 bands.
I started off not taking any of the positive tokens out but I found it not using 20%+ of travel.
Removing the extra +ve token has helped but I'm still not using full travel.
In general though it's a noticeable, good upgrade. I ride mostly steep tech, pretty choppy non manicured trials. The rear is certainly more planted, skips around less, so better grip.
Now the trails and bikes are a lot less muddy I'll take some tools out one day and spend a while swapping up and down the band range to see how it performs. Pumping to 295 psi each time is a drag though!
