Unanswered Magura Vyron eLECT Wireless Remote Dropper Post
super_claret
208
47
North Yorkshire
I'm considering the above dropper post but not sure if it will be suitable for my setup.
I have a Haibike SDURO Full Seven 7.0 in a small frame. The frame will allow the seatpost to be inserted a maximum 120mm into the frame and that leaves 150mm up to the seat bracket (see attached image), which is just right for my inside leg. I do quite often feel the need to drop the seat but I can't with the current seatpost.
Any advice would be appreciated, thanks.
cozzy
931
1,038
Hampshire UK
Have you checked out the way they work? They work in a weird way. The .5 seconds delay would drive me nuts I recon.
Review: Magura's Updated Vyron Wireless Electronic Dropper Post - Pinkbike
The Vyron doesn't behave exactly like a 'normal' dropper post. On most droppers you push a remote lever of some sort, lower the seat to where you want it with your body weight, and then release the lever to lock it in place. That's not the case with Vyron.
Instead, you push and release the remote button, and then there's a .5 second window to lower the seat. What if you push the button, weight the seat, and then unweight it in less than .5 seconds? That's right, it starts to raise back up, which is my biggest gripe with the Vyron. It's simply not as easy or as intuitive to use as a 'standard' dropper post, especially if you're riding somewhere with terrain that requires raising and lowering your seat more than a couple times.
super_claret
208
47
North Yorkshire
Yes, I am aware of the way it works and have read positive views from owners who have learned pretty quickly how to manage it. I think the fact that I won't have to faff about routing the cable will outweigh any other issues.
I'm more puzzled how to find out how much of this will go into the seat tube and how much
actual drop I will get out of it (using the 100mm version)?
552K
