GrandPaBrogan
⚡ eGeezer ⚡
Cake is better... then we can all eat it too. ?More pies = more traction
You are right, the strength of the tyres is what adds weight the most. I was a bit quick to write there. But surely you would survive with something else than "downhill" tyres?I've used lighter tyres before on previous bikes, and it's not grip that reduces with tyre weight, but strength and specifically resistance to punctures. With lighter tyres than these I always get flats.
Unfortunately for @Mteam I think you are right. The bike will never be a lightweight and it sounds like good advice to enjoy the bike as it is.Sounds to me like you’re not prepared to sacrifice anything, so you’re not going to be able to drop weight.
Unfortunately there is no magic way of shedding a kg, other than spending a fortune and sacrificing the bike.
I’ve got a Levo SL, and tried to get the bike to a spec I wanted, whilst making an effort to reduce the weight.
Some components added weight (better forks / shock / AXS dropper, tyres), and some removed (CF saddle, CF bars / Stem, CF cranks, CF brake levers, lighter cassette and lightweight pedals).
Overall the bike performs much better than stock, and is 800g lighter than it was.
at starting weight of 17.9kg, 800g is a big difference. Trying to shave 1kg off 24kg wont be nearly as noticeable.
All the suggestions above will shed weight - carbon rims, removing dropper (not practical IMO), lighter tyres, swapping drivetrain etc... however none of these are avenues you want to explore.
If that’s the case, then go out and enjoy the bike as is... or buy a lighter bike!
If you've ever tried a Levo SL you would know what we're talking about.I didn’t know I had joined a road bike forum, talking about saving grams on a bike, it’s a mountain bike for gods sake. It’s pedal assisted I don’t know how heavy my levo is, if I find it hard to pedal I just stick it in turbo ?.
Yeah, I'd come to the same conclusion myself in the first post, but just wanted to get the panels opinion in case I missed anything, I've tried most of the suggestions (carbon rims, light tyres) on previous bikes and come to the conclusions that for me, they are not worth the compromise.Sounds to me like you’re not prepared to sacrifice anything, so you’re not going to be able to drop weight.
They're not actually downhill tyres, the front is the exo plus casing, and the rear is the doubledown casing, maxxis also do an even heavier dh casing, which is overkill for my needs.You are right, the strength of the tyres is what adds weight the most. I was a bit quick to write there. But surely you would survive with something else than "downhill" tyres?
Did a quick calculation.
Your weight saving 4.47% , 1kg of 24kg is 4.17% so very similar.
Also, hate to think how much that little lot cost you. Can’t think you got very much value out of some of the upgrades. CF bars yes and also the cassette but how much weight did the stem or brake levers really save? Not slagging you off, just interested. I understand lots of small changes all add up but at what cost?
I’ve got a whole thread on it if you’re interested!
Levo SL Gen 1 - Levo SL Expert - my build thread.
I’ve got a test ride thread out here somewhere that has details of my build in it - but here’s the info in an easier to read format rather than spanning over loads of posts... My Bike: Specialized Levo SL Expert - Size XL What’s changed: Full Invisiframe kit SRAM XX1 AXS derailleur SRAM XX1...www.emtbforums.com
My goal wasn’t all about weight saving - it was to get the bike to the spec I wanted. The bars and stem are off my previous bike, so didn’t cost anything at this time.
Although the brake levers are lighter than the stock ones, they were bought specifically for my Raynauds Syndrome (cold fingers / toes) as carbon doesn’t feel as cold on your fingers in cold temperatures.
If I wanted, I could easily get my bike to ~16kg by putting on lightweight tyres, swapping the dropper for a carbon post and a few other tweaks... but then the bike would be no use for where I ride it!
I could knock 500g off by putting back on the stock dropper / fork / shock... but that wasn’t the aim of the game.
Stem saved more weight than I thought, plus a no brainier if you had it already.
Damn you though, those carbon cranks are gorgeous. Must resist.
Totally agree on the AXS kit, amazing stuff. Well worth any weight penalty.
I’m down in Angus, maybe meet sometime for a loop of Heartbreak Ridge once lockdown lifts.
Biggest weight saving will be wheels/tyre & battery but do you want to compromise these? Weigh your wheels, tyres rotors cassette etc will be around 5kg I reckon for both
First post
Recent post
Sorry, I am a little confused
XTR cassette? 100g is 0.4% of your 23kg bike... less than half of 1%
Is that your idea of a significant weight saving? without spending a fortune ? ?![]()
The only option I can come up with is buying an additional 500wh battery, and using that for most rides, keeping the 625wh battery for big rides, that would drop it to about 22.5kg, but I'm wondering if anyone has any clever/thinking outside the box ways of shedding weight without affecting the things that matter.
Where's the 'blows kisses' emoji?You've been given tons of options at half your £1 per gram criteria but dismissed almost all of them.
It doesn't bother me in the slightest and I haven't noticed anyone else get annoyed but you are wasting everyone's time here.
Give it a try . I think you will be pleasantly surprised.I've got a spare 27.5 wheel here that would fit but i think it will lower the bb by too much, might give it a try though when I get bored.
