Is the bike updated to the latest fw?
Thanks for your reply,Is the bike updated to the latest fw?
Yeah, usually there is no specific reason for bugs being in a software also ... I had this same error occasionally and since updating to firmware 7.4.1 in December 2020 fixed this issue. Release notes of this update has a note "Bug fix for incorrectly triggered motor reset error" and I presume this was it, no errors since then ...there is no reason for the bike to show a motor error merely because it may not have the latest update!
FYI these tasks can be done without removing the motor...Thanks for all your replies, it was riding fine with no issues. The error code came up after I removed the motor to install a new Shimano cassette derailleur and brakes. Its a 2019 bike with a new gen 2 battery. I gather any software updates has to be done by Specialized?
Sorry, I also re installed new gear and brake cables. Also tried multiple times not able to connect to TCU via appFYI these tasks can be done without removing the motor...
You can update fw of the motor and TCU by yourself OTA via MC app.
I had this error while riding at full power on a hot day. I unplugged the battery on the trail and left it unplugged for 30 seconds and then plugged it back in. The error cleared and didn't come back. I consider it some sort of glitch in the code, or an overheat error. Dunno for sure.Manual says motor error- Try rebooting or checking Mission Control App for more information. Contact your Authorized Specialist Retailer.
Have you tried disconnecting the battery?
Thanks, appreciate your time.Have you also tried connect to the TCU using different smartphone? I persume you are entering correct BT code... If this also doesn't work then you apparently have a problem with TCU and you should visit your dealer anyway ...
Ill give that a go!I had this error while riding at full power on a hot day. I unplugged the battery on the trail and left it unplugged for 30 seconds and then plugged it back in. The error cleared and didn't come back. I consider it some sort of glitch in the code, or an overheat error. Dunno for sure.
