Levo SL Gen 1 Levo SL max rear tyre width
alexhalliow
37
Isle of Wight
Hi all sorry if that has already been covered.
what’s the max width people have fitted to Levo sl? I’m looking at some Michelin E-Gum 29” 2.6
should there be enough clearance for these?
also- has anyone been able to get a power supply from the SL to power a GPS tracker?
Ntinos
51
39
Athens, Greece
Because I have maxxis dhrII 2.4 and I can imagine how close to chainstays bridge the Michelin 2.6 (which I had on previous bike, and are bigger than the dhrII 2.4) will be.
levity
539
1,598
SoCal
^^ Thanks.
Here's a Maxxis Rekon 29x2.6 (i36 rim) on a Comp Carbon SL. The tire measures a true 2.6" at the knobs and casing.
Clearance measurements measurements were made by inserting a hex key in the gaps.
seatstay cross-bridge has ~7mm clearance
chainstays have >10mm clearance
mudflap/chainstay bridge has ~6mm clearance
Note that full compression of the shock moves the 2.6 tire to within ~2-3mm of the mud flap.
The Rekon knobs aren't very tall, so a tire with bigger knobs would have less clearance.
Another issue is that the taller tire raises an already high bottom bracket.
576K
