levo know problems rant ....
Bryan Wells
120
140
Washington
mine is a 2019 expert 700wh batt. I run at 70% . power max and stay in larger gears to avoid extra strain. I feel like the motors are becoming a wear item on the scale of replacement tires...
randycpu
111
47
Silicon Valley, USA
I wanted to replay to all those saying things like "Spesh will sort this out and support you":
Yes, until your bike is exactly one year old. After that their only explicit obligation is to sell you repair parts.
How much do you think these parts cost? Cable, Motor, Battery?
wepn
The Barking Owl ?
Jul 18, 2019
1,006
1,145
AU
Except that:
"All model year 2016 to 2018 (presume that includes 2019 & 2020 models?) custom Brose motors are covered by a two-year / 15,000-kilometer warranty (whichever is reached first). Faults due to manufacturer defects during this period are covered under this warranty"
Specialized.com
Probably around USD$1100-1200 each for motor and similar for a battery. Not bad when you consider your motor & battery are likely to last well beyond the warranty period. Compare that to any other form of recreational vehicle.
jwrx
206
243
Malaysia
my 2018 motor died around 1200km, battery also died same time, both covered under warranty. Sold the bike..currently using a 2019 levo..almost 600km. flawless so far..but it seems to have a issue with heat retention...it cant take full on turbo blasts of more than 20-30min intense climbing...output drops quite abit till i rest and let it cool down
wepn
The Barking Owl ?
Jul 18, 2019
1,006
1,145
AU
Sounds like a lot of impressive motor abuse & that's really how it's meant to be. Thermal rollback with the slightly less favourable thermal qualities of magnesium vs aluminium vs ?
Do you know what temperature the motor is when rollback starts? Maybe 90°C ?
jwrx
206
243
Malaysia
yes. thats my suspicion also..cos i could do the same trails on the 18 without the drop in power.
I will monitor with the spez app motor temp next ride.
Makes me wonder...this could be the reason spez left the rear of the 19 open to the elements, it was meant as a heat exhaust...but ended up being a mud collector. Spez rolls out fixes to close the gap....and ends up defeating the original purpose of venting heat
6,657
5,142
Thats why they just used moto foam. It still breathes but stops dust and mud filling up the motor covers.
jwrx
206
243
Malaysia
Sigh.
2018 Sworks, battery and motor failed at 1200km - warranty covered and sold
2019 Expert, motor failed at 500km. Happened today, no signs at all..happily powering on a uphill,..then suddenly it sounds like a electric chainsaw on turbo
sending in for warranty tomorrow. Sounds like a belt has kaput
561K
