Levo Gen 3 Levo/Kenevo motor replacement procedure
Chris_R
Switzerland
Hi all,
I'll likely need to replace my motor. It's out of warranty (2021 Kenevo in Switzerland imported from Germany with a motor replacement done by a LBS in 2022). I'll try my luck with the LBS to check for a warranty claim or at least some cost reduction. However, since this is Switzerland, I'm considering to change the motor on my own. So my question:
- will the motor replacement be plug & play or do I need any special tools and especially software to reset the firmware or so? As said, it's a 2021 Kenevo so it still does have the original TCU, not the mastermind unit.
Cheers and thanks for your answers
DylanJM
162
203
Denmark
Specialized have a discounted replacement plan for out of warranty replacements depending on how far out of warranty you are i.e. the longer you are out the smaller the discount.
Apr 11, 2023
119
24
Japan
Hi all,
Is the motor fairly easy to take out? Have you come across any useful YouTube videos on how to take out the motor? I ask, because my motor is making a whistling or whirrring sound, and so I'm worried that I'll have to replace the motor soon. But I'll have to take the motor out myself, because I'm in Japan, and they don't sell or service the Levo here. I'll have to take it to Taiwan.
Binhill1
🍊 Tango Man 🍊
Mar 7, 2019
3,804
6,000
I've changed two myself not hard really. Take some pics as you go to remember which plugs go where in motor,and anything else you dismantle. Only 6 main bolts on my 19 levo. I'm no wizard mechanicly either. Worth changing cables out if the need done while it's out. Good luck. 2019 Levo expert I have . Be careful taking out speed sensor cable from motor it's very delicate.
Chris_R
Switzerland
Thanks, so you didn't need any firmware flashing or something of sorts?
Binhill1
🍊 Tango Man 🍊
Mar 7, 2019
3,804
6,000
No I just fitted motor it was posted to me. But I needed a new TCU in January so that has to be paired with the motor and frame so my choice was do local or send motor to Berkshire Cycles who supplied TCU and that's what I did . All good now .
574K
