Levo Gen 4 Levo Gen 4 Rumours and some facts...
Status
Not open for further replies.
salko
1,355
926
SLO
I can only see GCLMET/REDPRL/BLKPRL
In my opinion that´s the color comination for only one paintwork. "GCL" can be Glassical Metallic, in combination with Red Pearl (REDPRL) and Black Pearl (BLKPRL). Black Pearl might be the description for the S-Works logo on the top tube.
Well I definitely cannot see any red and black color on Glacial Metallic frame, the sworks logo looks lighter, maybe white or light silver ...
Dax
1,845
2,287
FoD
Seriously even the friken Santa Cruz has a wireless controller ,am I being stooped but does the Sworks have a hardwired controller still ( I was only joking but looking back at the pics its hardwired) o_O
So even the friken Santa Cruz has a battery in the controller that will leave you stranded when it goes flat?
salko
1,355
926
SLO
Well this is also possible, maybe they have metallic color which has a reddish tint in it, which you can see only by looking at particular angle or at particular lightning ... I guess we'll have to wait and see ...
Georgedukesa
130
103
Johannesburg
Like I said fast chargers and being out on a ride not knowing that your. Batteries about to die only makes it idiot proof really isn’t brain surgery to check the power of your chargeables every now and again
salko
1,355
926
SLO
Any reasonable good system will warn you way ahead of empty battery that you should charge up the battery ... and many systems have a backup option for changing the support level, even Levos have it on the TCU if your remote suddenly stops working ...
emtbeast
403
458
Slovenia
ok, this is a mock up based from an SL image then hand drawn to reflect what we know/think we know .. proportions and angles will probably be slightly off.
Are u sure this is a mock up 🧐, have seen the real life pics of the bike including specs and this looks like 99,9% close to it, imo the design language kinda fades into the plethora of all the other offerings on the market.
Dax
1,845
2,287
FoD
Is the controller rechargeable? I was thinking of the old days where the bosch(?) controller needed a button cell or it wouldn’t worked and loads of riders carried a spare button cell in their packs. Personally don’t see any disadvantage of a wired controller and quite a lot of advantages
Georgedukesa
130
103
Johannesburg
Just makes the cockpit full of cables less is more for me personally , for me its about the tech , and the e-bike of any brand is the bleeding edge of that tech so when a industry leader become slap gat and doesn’t use those top products to their advantage kinda sloppy , but that’s my opinion
Power1tobe
62
41
VA
So there are only 2 colors in S-works Glacial Blue like above and Red pearl that transitions to black going down the down tube.
Only the S-Works has fast charge
$13.5K S-works
$11.5K Pro
21,490
So based on you and @Flo7 , we can say it's similar looking.
Yup, I just took the SL S-works frame and modded the drawing. If you drop the sL image over it, you'll see it matches exactly.
I had the same conversation with the Mods when they deleted the image and had to prove it was a mock up. Slimed the display, changed the angle of the seat tube kink, enlarged the downtube (suspect it's far from accurate especially near the steerer) Flattened the motor top. Enlarged the motor area. Modded the seat post as per Flo7 comment - though it doesn't run at the same angle as the modded seat tube. Widened the seat stay (because I messed up the angles) Buttressed the seat stay bearing area, partly due to changing the angle. Upgraded the cage. Upgraded the shock(well, ish). Added extra water bottle/tool kit bosses, but ended up deleting one by accident. And yes, there is a Cannondale crank in there when I tried to use a Bosch motor area. You'll note the bottom chain line doesn't run straight, I kinked it from the tire onwards and didn't bother with the top chain line as it's sunny and I couldn't be arsed :)
Power1tobe
62
41
VA
100% what it looks like! No S-Works sticker and down tube a little fatter.
Closer- Now the motor looks a little to big.. looks closer to SL size.. maybe the shadow
salko
1,355
926
SLO
I had the same conversation with the Mods when they deleted the image and had to prove it was a mock up. Slimed the display, changed the angle of the seat tube kink, enlarged the downtube (suspect it's far from accurate especially near the steerer) Flattened the motor top. Enlarged the motor area. You'll note the bottom chain line doesn't run straight, I kinked it from the tire onwards and didn't bother with the top chain line as it's sunny and I couldn't be arsed :)
I see what you did there :ROFLMAO:
Status
577K
