Kiox 300
pinoymamba
39
10
I’ve had random shut offs thinking it was from the wires from the Kiox to controller. Today I had the most awful experience on a ride it shut off so many times. Usually it’ll shut off when the bars were turned too much. I ended up just bypassing the Kiox. Works flawlessly now without any shut offs. Anyone have experience with and Kiox or should I just get a new cable. I’ve read those go bad…
Hattori-Hanzo
270
279
If it's only shutting off when turning the bars, thus putting strain on the cable my first thought would be either a damaged cable (sometimes the damage can't be seen externally) or the connection port into the kiox.
pinoymamba
39
10
Just found it odd it was working perfectly fine to random turn offs the following day. I will purchase a cable first. The way they designed the cabling and mount for the Kiox is very dated.
west
13
NZ
This is why Trek put the Kiox 300 in the top tube.
So much better having it there, have had some huge crashes and no issues at all. Screen information is quite useful, just be nicer if it sat flush inside the top tube.
526K
